Ford 2910 will not start, opinions needed!!
   / Ford 2910 will not start, opinions needed!! #1
cgr
Opelousas, La
John Deere 5103
I have a ford 2910 and will not start, rolls over. Any suggestions? Have fuel to pump. Could it be injectors , thx.
   / Ford 2910 will not start, opinions needed!! #2
is it making smoke?
does this have a key off setup? if so.. check fuel solenoid.
bottm line. if it is not making smoke.. it is not getting fuel.
so lets start there.
I just went back after 30 minutes and turned over and started good!!! Have no clue why it didn't start first time. No it didn't smoke while trying to crank first time.
   / Ford 2910 will not start, opinions needed!! #4
then it had no fuel.
might have gravity bleed a bit.. or you stopped just shy of it starting last time. ;)
K. Should I bleed the fuel system ? If I do that I will also change fuel filters. Thx for info !!
   / Ford 2910 will not start, opinions needed!! #6
sounds like it is bled now if it starts...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
