Ford 2910 will not start, opinions needed!!
   / Ford 2910 will not start, opinions needed!! #1
cgr
Opelousas, La
John Deere 5103
I have a ford 2910 and will not start, rolls over. Any suggestions? Have fuel to pump. Could it be injectors , thx.
   / Ford 2910 will not start, opinions needed!! #2
is it making smoke?
does this have a key off setup? if so.. check fuel solenoid.
bottm line. if it is not making smoke.. it is not getting fuel.
so lets start there.
I just went back after 30 minutes and turned over and started good!!! Have no clue why it didn't start first time. No it didn't smoke while trying to crank first time.
   / Ford 2910 will not start, opinions needed!! #4
then it had no fuel.
might have gravity bleed a bit.. or you stopped just shy of it starting last time. ;)
K. Should I bleed the fuel system ? If I do that I will also change fuel filters. Thx for info !!
   / Ford 2910 will not start, opinions needed!! #6
sounds like it is bled now if it starts...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
