Ford 2810 Power Steering
   / Ford 2810 Power Steering #1
jgriswol538802
Winder, GA
I looked at a Ford 2810 yesterday. THe meter shows about 1200 hours. The tractor appears in over all good shape. The power steering did not seem to be working well, if at all. Does the PS work off the same hydraulic fluid that is in the transmission? There is a dip stick located right next to the gear shifts and it shows full and the fluid looks clean. Is there another dip stick anywhere that should be checked?
Any ideas would be appreciated.
   / Ford 2810 Power Steering #2
Power steering is a dedicated system with the pump/reservoir mounted on the front left of the engine. Fill with New Holand 134D hydraulic oil or the equivalent. Reservoir is full when oil runs out the fill port.
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2017 John Deere 6195R (A50120)
2017 John Deere...
2012 Terex RL4 S/A Towable Light Tower (A50322)
2012 Terex RL4 S/A...
1994 White 6065 Tractor (RIDE AND DRIVE) (A50774)
1994 White 6065...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
