Ford 2600 steering sector seal leak
   / Ford 2600 steering sector seal leak #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV 900X Mahindra 4540 4WD w/Loader
I posted this once before with no response. I need to replace the steering sector seals and would like to know if they can be replaced without removing the steering box. Reading the repair manual it's not real clear.
   / Ford 2600 steering sector seal leak #2
is this a power box?
The tractor has power steering but the leak is in main gear box not the power valve. It's just like the manual gear box and uses 90w oil in it.
   / Ford 2600 steering sector seal leak #4
I'm quite familiar with the layout of the box, I asked because a straight manual box I easier to remove than a power box, and that was part of the question asked, you can handle it from here.
   / Ford 2600 steering sector seal leak #5
Yes you can replace those seals without removing the shafts.
Just dig the old ones out with a screwdriver, etc then find a piece of pipe or conduit, etc the right size and tap the new ones in.
EZ.
EZ.
Thanks, that confirmed what I thought.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
