Ford 2600 diesel running rough, black snmoke.
   / Ford 2600 diesel running rough, black snmoke.
No it doesn't knock.
   / Ford 2600 diesel running rough, black snmoke. #23
Does it have a turbo or naturally aspirated? Does it have an ECM or all mechanical? I'd have injectors checked also. Those 3 things have caused similar black smoke & rough idle/running in my big truck motor in the past..... Is it using oil now where it didn't in the past? May be another bigger issue if so
   / Ford 2600 diesel running rough, black snmoke. #24
I mean this sincerly, I hope you don't have to have the fuel injection rebuilt. I had a early cylinder ford 4000 diesel and was gonna have the fuel pump rebuilt well I priced the service from a local fuel injection service $800. I simply could not afford that. I sold the tractor, end of story. I found out the hard way a diesel isn't always the most economical way to go. bjr
   / Ford 2600 diesel running rough, black snmoke. #25
Hello everyone,
My 2600 has been running rough, is low on power, and emits black smoke when revved up. It's been bad the last few days, but I'd noticed loss of power over the last couple of months. It starts right up and idles OK. I can't see any leaks, in the past when it acted like this I've needed to replace an injector line, but no apparent leaks this time. Where should I start looking?
Thanks!
Is you air filter/manifold clear? . Black smoke is indicative of a high fue/ air ratio. Blocked air filters reduce power since horsepower is proportional to airflow.
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
BUSH HOG 7007 LOT NUMBER 111 (A53084)
BUSH HOG 7007 LOT...
2005 CHEVROLET SILVERADO (A52472)
2005 CHEVROLET...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
