ford 256 bsd 442 compression check injector adapter and specs?
   / ford 256 bsd 442 compression check injector adapter and specs? #1
Mountainmover
Ford 3600
Hello.
I have a ford 256 bsd 442 engine. I wanna do a compression check. I have a generic compression test kit for tractors but I cannot find the right adapter. Does anyone know the specific type and size? How to find? An online link?
Also, what is the compression test info? Engine is in a crate and not on a tractor but i have a flywheel and starter rigged up.
Engine has the clamp down type injectors and is a webbed block engine.
thanks!
   / ford 256 bsd 442 compression check injector adapter and specs? #2
Hello.
thanks!
Diesel Engine Compression Tester 2 Pc
   / ford 256 bsd 442 compression check injector adapter and specs? #3
Lang M21 adapter.. or.. I think the H. Freight BIG compr. kit has an adapter??
Anything over 300psi will start a diesel.. I don't know the actual spec. anything under 300 is considered bad.
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
UNUSED HURRICANE...
2021 BOBCAT T66 R-SERIES SKID STEER (A51246)
2021 BOBCAT T66...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
