ford 256 bsd 442 compression check injector adapter and specs?
   / ford 256 bsd 442 compression check injector adapter and specs? #1
Mountainmover
Ford 3600
Hello.
I have a ford 256 bsd 442 engine. I wanna do a compression check. I have a generic compression test kit for tractors but I cannot find the right adapter. Does anyone know the specific type and size? How to find? An online link?
Also, what is the compression test info? Engine is in a crate and not on a tractor but i have a flywheel and starter rigged up.
Engine has the clamp down type injectors and is a webbed block engine.
thanks!
   / ford 256 bsd 442 compression check injector adapter and specs? #2
Hello.
thanks!
Diesel Engine Compression Tester 2 Pc
   / ford 256 bsd 442 compression check injector adapter and specs? #3
Lang M21 adapter.. or.. I think the H. Freight BIG compr. kit has an adapter??
Anything over 300psi will start a diesel.. I don't know the actual spec. anything under 300 is considered bad.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2011 Chev Impala (A51694)
2011 Chev Impala...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
