ford 2120 with HSS shuttle shift problems
   / ford 2120 with HSS shuttle shift problems #1
mikeleonard
blue ridge va
ford 2120
I have a ford 2120 with HSS shuttle shift that will not shift from netural. Have check the shifting solenoids mounted at the steering column and they are getting voltage and seem to be working. Any other ideas?
   / ford 2120 with HSS shuttle shift problems #2
:welcome: From Ohio
   / ford 2120 with HSS shuttle shift problems #3
Welcome Mike to TractorByNet.
   / ford 2120 with HSS shuttle shift problems #4
You mean the reverser won't shift out of neutral? Or the 4-speed ?
Jim
   / ford 2120 with HSS shuttle shift problems #5
There is a hydraulic valve that sits at the bottom of the steering column just in front of it that has a cable coming from the clutch pedal to it. If that cable gets kinked or something is preventing that valve from closing it will prevent the tractor from moving. Also I once washed my tractor and got the computer box wet that sits just behind the base of the steering column and my tractor wouldn't move for 2 days then finally after it dried out everything was fine again. Needless to say that box and the solenoid on the shuttle shift are protected with a thin layer of rubber mat slid over the shifters any time it's raining and the tractor is kept inside.
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
44052 (A55852)
44052 (A55852)
