2120 lazy shuttle
   / 2120 lazy shuttle
the cable to the lube cutoff spool was missing. installed a new one, clutch seems to be a little faster at engaging,when i use the pedel ,but shifting f to r is still like poping the clutch it grabs and spins the tires.changed the filter again and it was dirty. friend of mine wants to adjust the relief valve .hop that helps i can't believe the tractor is suposed shift that hard
   / 2120 lazy shuttle #12
Mine is the EHSS so there is a dash switch to change the engagement "speed" of the reverser. I leave mine in rabbit, as the turtle setting takes 1ス-2 seconds. There is no harsh engagement, though, with either setting even at high engine rpm. Something is still not right with yours. Good luck.
Jim
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2020 DRAGON ESP...
Topsoil Trommel (A57453)
Topsoil Trommel...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
