Ford 2120 HSS transmission problems
/ Ford 2120 HSS transmission problems #1
Tom stout
Pataskala
ford 2120
I have a ford 2120 with the hss transmission. When placed in gear the tractor sits a while and then takes off.The same is true when stopping and shifting to reverse.The clutch pedal has an inch of use at the very top of travel. The pto does not work at all.Once moving the tractor seems fine and operates the loader with no problems. fluid levels are good. This problem has gotten worse over time. Tractor has 2400 hours
