FORD 2110 - Replacing Freeze Plug
   / FORD 2110 - Replacing Freeze Plug #1
desertjim
Deming. NM
Ford 2110
Hi All, I lost a freeze plug during the winter and need to replace it.
PROBLEM is: It's behind the Injector Pump.
A guy I know is an x heavy equip mechanic and he said I'd better be careful because of the timing; that he thought there was a rod running from the Pump into the engine which controls the timing.
Has anyone had to do this operation? Does anyone know if the injector pump is timed in this manner?
Thanks for any information. I don't mind R&Ring the Pump, but need to know how to make sure I don't mess up the timing.
   / FORD 2110 - Replacing Freeze Plug #2
Best thing is to secure the proper manual for that engine
   / FORD 2110 - Replacing Freeze Plug #3
Not an expert but all injector pumps are timed
   / FORD 2110 - Replacing Freeze Plug #4
you should be able to pull pump off and put right back just make sure you don't turn the motor or pump
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2015 Lexus RX 350 SUV (A48082)
2015 Lexus RX 350...
UNUSED INDUSTRIAS AMERICA R2232 HYD DISC HARROW (A50459)
UNUSED INDUSTRIAS...
Hot Stick 12ft Trailer (A48837)
Hot Stick 12ft...
2012 DODGE RAM 5500 HD SERVICE BODY (A50505)
2012 DODGE RAM...
