FORD 2110 - Replacing Freeze Plug
   / FORD 2110 - Replacing Freeze Plug #1
desertjim
Deming. NM
Ford 2110
Hi All, I lost a freeze plug during the winter and need to replace it.
PROBLEM is: It's behind the Injector Pump.
A guy I know is an x heavy equip mechanic and he said I'd better be careful because of the timing; that he thought there was a rod running from the Pump into the engine which controls the timing.
Has anyone had to do this operation? Does anyone know if the injector pump is timed in this manner?
Thanks for any information. I don't mind R&Ring the Pump, but need to know how to make sure I don't mess up the timing.
   / FORD 2110 - Replacing Freeze Plug #2
Best thing is to secure the proper manual for that engine
   / FORD 2110 - Replacing Freeze Plug #3
Not an expert but all injector pumps are timed
   / FORD 2110 - Replacing Freeze Plug #4
you should be able to pull pump off and put right back just make sure you don't turn the motor or pump
Bolens G272 Tractor (A50860)
Bolens G272...
2014 Infiniti QX60 AWD SUV (A48082)
2014 Infiniti QX60...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1265 (A50490)
1265 (A50490)
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
