Ford 2110 Compact tractor transmission HELP
   / Ford 2110 Compact tractor transmission HELP #1
kittyhawk
Buffalo, Texas
JD X300 X350 Lawn Tractors. BRANSON 3620H
Hi guys I need some HELP!.
I was mowing on Sunday morning and went to shift gears from 3ed to 2nd and went straight down and got it in 4th by mistake and now its stuck in 4th. I cannot get it to pop out of 4th, its stuck and I've done everything I can think of to get out. I tried to get it out by rolling with load with no load, shifting ranges and to reverse, engine off, engine running and pto on, pto off. Ive tried everything!
I don't want to pop the shift lever cover off since I don't want to get in over my head.
Dose anyone have experience with this issue or have a fix? Also the tractor is Located in Buffalo TX, if anyone's interested.
I checked and the fluid is topped off and fresh and the clutch feels good and doesn't need to be adjusted.
Dave
   / Ford 2110 Compact tractor transmission HELP #2
I don't know that tractor but I'd say go on and pop the cover off. Might just be stuck. Plus you'll be able to see if anything is broken.
   / Ford 2110 Compact tractor transmission HELP #3
Do you have the regular trans, twin stick? Range shifter on the left and trans shifter 1-4 on the right. Or do you have the shuttle shift?
I have had the same issues on my 1910 with twin sticks, for lack of a better term. On mine as I recall there are 4 bolts nearer the center of the cover one behind each stick and one in front of each, under these are detent balls and springs. Try taking the bolt out, put your thumb over the hole and move the lever out of gear, then just reinstall the bolt and you should be good to go!
Good luck!
Thanks guys, it has the 1-4 on the left and ranges and reverse on the right. I will try pulling the detent balls out to see if it will let it shift, if not I will pull the top cover. Question, do I need to pull the detent balls and springs out before pulling the top covered off? Also do can the gasket be reused or do I need to put some permatex on it to reseal it?
   / Ford 2110 Compact tractor transmission HELP #5
If its like mine, try removing the bolt closest to where it’s stuck, with thumb over hole before moving lever if not the detent ball will go flying! If you need to remove cover, YES remove detent ball and spring (all 4) first use a pick to remove, you don’t want to fish detent balls out of the bottom of the transmission (been there done that) if the gasket comes of in one piece just wipe and reinstall.
Thank you guys, I蜘ill work on it next weekend, the weather man is perdicing 5 plus inches of rain this weekend.
10' CONTAINER (A57193)
2014 Ford Explorer Limited SUV (A55853)
2014 Ford Explorer...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2002 Club Car Carryall 2 XRT Gas Utility Cart (A55851)
2002 Club Car...
