Ford 2110 (1986 Japanese model) hard starting when cold
   / Ford 2110 (1986 Japanese model) hard starting when cold #1
MadJack
Litchfield, Maine
86 Ford 2110 4x4
The glow plug heater helps a little but it still only starts on 2 cylinders, and only when it feels like it. (black smoke when it tries to start)
I was told today it may be a couple dead glow plugs.
It started pretty well August/September, and always runs well and smooth once started.
So what's your thoughts on this being a glow plug issue?
Thanks
   / Ford 2110 (1986 Japanese model) hard starting when cold #2
On a tractor that old I would bet it has some dead glow plugs.
You can test them with an ohm meter.
That said glow plugs (SBA185366060) typically don’t cost too much, so I‘d replace all of them.
SBA185366060HVACSTAR 3pcs Glow Plug SBA185366060 for New Holland Tractor https://a.co/d/dc0O3xI
   / Ford 2110 (1986 Japanese model) hard starting when cold #3
Use a voltmeter to see if you're even getting voltage to the glow plugs. If you're getting power check to see if they're open or burned out. You should also check your air filter and air path to the intake manifold.
SBA185366060HVACSTAR 3pcs Glow Plug SBA185366060 for New Holland Tractor Amazon.com
Thanks DS80! That part number comes up at $9 each and is listed for over 70 machines. I ordered 4 and should have them Friday or Monday.
I am working through lack-of-maintainence issues from the previous owner(s), and $36 is a cheap check-off from my list.
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
