Oil & Fuel Ford 2000 won't stay running
   / Ford 2000 won't stay running #1
crhodes07
Tyler,tx
Ford 2000
I'm new to the tractor world and really looking for some help. When I first received the tractor it'd only run with the choke all the way open. I pulled the carb and cleaned it up, sealed it with RGV type stuff out it back on.
I also spliced in an in line fuel filter with some rubber hose. Turned out that didn't work-after I cut up my fuel line anyways I took the filter off and just put a fitting in between for the rubber hose to just be complete. Well now I'm getting fire, but it won't idle. Guessing I'm not getting fuel or something, but when I empty the bowl on the carb fuel comes out. I don't know the year of the tractor, only that it's a ford 2000 gasser 3 cylinder engine. Somebody help please!!
@kirkawilson it did not
But I read through it and some of the comments. It seems he and I have a similar problem. But mine will not "run" at all. It fires, but I cannot get it to stay running without having the key bumped over to the crank position.
   / Ford 2000 won't stay running #5
If it will run in the start position of the switch, but dies when the spring returns the switch to Run, see Rick B's post about the resistance wire between switch and coil. Older cars used a ballast resistor, newer a resistor wire. If that wire or ballast fails open, your coil only gets current in the start position, not in the run position. See SteveV's post in the linked thread.
Jim
I don't know enough about tractors to understand what they're saying. If I take a photo can one of y'all point me in the right direction?
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
23222 (A50323)
23222 (A50323)
Pallet Fees (A50775)
Ford Tractor (A50120)
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
