Ford 2000 PTO quit
   / Ford 2000 PTO quit #1
Kwalityguy
Denton, TX
Ford 2000
I have a 1967 Ford 2000 gas tractor with an 8 speed transmission. I was brush hogging and almost done when the PTO shaft quit turning at its normal speed. Turning slow enough that I couldn't finish mowing. Everything else seems fine. Any ideas as to what the issue is?
   / Ford 2000 PTO quit #2
Is it the PTO or the brush hog? Did you unmount the bush hog and check to see if the PTO itself was turning?
The shaft connecting the PTO to the brush hog slowed and stopped turning. I did not disconnect the brush hog. I would thing that if its in the brush hog, the connecting shaft would continue to turn due to no load from the brush hog or bind up and stall the engine.
There were a couple times mowing through heavy grass that loaded the brush hog down enough to drop the rpm. Did that stress cause some kind of damage? This is almost a 50 year old tractor. Don't know how old the brush hog is.
I'll be back out at the farm in two days so if there's any suggestions ill check while I'm there. I have a service manual but it only shows parts. Doesn't have a troubleshooting section.
   / Ford 2000 PTO quit #4
Does your 2000 have the live PTO? If so, it could be the clutch.
I'd first take the above suggestion and look carefully at the output shaft, it could be a problem with the shaft itself. That's a long shot, but the first thing to check...
   / Ford 2000 PTO quit #5
Yep, is it a live pto? (2-stage clutch)?? if so, clutch could be done for.
What model 2000 do you have. The earlier 4 cylinder ones that had rounded hood kinda looking like the N's??
Or the later 3 cylinder one with the squared hood??
IF the early one, it was live PTO. The later one could be either. But if it is transmission driven, you likely broke something and arent just dealing with a worn clutch.
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Wright Sentar (A50120)
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
