Ford 2000 4 Cyl hydraulic lift doesn't work
   / Ford 2000 4 Cyl hydraulic lift doesn't work #1
ThePiddler
Hot Springs Ar
Ford 2000
Please help!
I have a 2000 Ford (4cyl diesel) tractor. Hydraulic lift had been working erratically for a while but then a couple of months ago it just quit lifting altogether and I am just now getting around to trying to figure out what to do with it. I have spent several days researching this problem and after trying all of the following, I run out of things to try. Please help!
First, an issue of milky hydraulic fluid was corrected by draining & flushing with new fluid and then refilling to the fluid level test port on the right side of tractor (does not have dip stick). Removal of the plug on the hydraulic pump at first revealed very little erratically spurting fluid with tractor running so after replacing plug, I made several attempts to pressurize the system (at fluid level test port) in an unsuccessful attempt at priming the pump. (This was done while moving the lift lever up and down with engine off and also while running). Next, after replacing the test and fill plugs, I tried to pressurize the system by sending air pressure backwards to the reservoir thru the plug port on the hydraulic pump. My theory was that if the screen was blocked, this pressure would free the blockage as well as pressurize the system and in return force the fluid back up thru the pump still no fluid at the pump (multiple times with engine on and off). After pouring several ounces of fluid into the pump (using a fill hose at the plug port) both with and without being followed with air pressure, I could hear the air going into the reservoir but again after multiple attempts with engine on and off still no fluid at the pump, not even the original 兎rratically spurting fluid? I don稚 know if this has anything to do with the issue or not but I have also found that the draft control lever will not move to the upwards position that痴 shown in many of the online pictures I can find. It seems to only have about シ movement in either direction but I am not familiar enough with this particular unit to know if that is natural or what. I would appreciate any ideas that might prevent me having to do a possibly unnecessary surgery on this thing! Thanks in advance.
   / Ford 2000 4 Cyl hydraulic lift doesn't work #2
Check all orings on inlet side to pump. I would recommend pulling the lift cover or inspection cover and servicing filters along with seeing what's binding lift. I had a similar issue with my 3500. What started out as a loose suction feed line to pump, led to complete axle disassembly, filters were in pieces, pieces got pulled into pump etc.... You may also have better luck in the new Holland section, or go to related equipment- vintage tractors- then Ford. Either way, welcome to the forums
Thanks for your input. It sounds like surgery is what its going to take to fix this thing after all. I really do appreciate it. ThePiddler
   / Ford 2000 4 Cyl hydraulic lift doesn't work #4
First.. No screen, 2nd, why no dipstick? Should be by the pro shifter. This test check plug you checked to.. This wasn't the one on the tranny right?
Hyds and rear and trans are separate
LOT LOCATIONS (A52577)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
