Ford 2000 3 Pt.lift problems
   / Ford 2000 3 Pt.lift problems #1
SM64
Ford 2000 3Cyl.
I recently replaced the PTO shaft seal on my Ford 2000 3cyl.gas tractor. The 3 Pt.was working fine before I replaced the seal.After replacing the seal and refilling the rear end with Hyd.fluid , when I try to prime the Hyd. Pump with the tractor idling, there is no fluid coming out of the pump at the bleed screw. Thanks for any help!
   / Ford 2000 3 Pt.lift problems #2
Maybe the pump is a bit worn and doesn't suck as good as a new one. I'd suggest you up the RPMs to get better suction and have the 3 pt lift lever in the down position....if that matters....won't hurt.
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
Bush Hog RMB 1865 Ditch Bank Mower (A50120)
Bush Hog RMB 1865...
Stehl Tow Dolly (A50514)
Stehl Tow Dolly...
