Ford 2000 3 cylinder lift problem
   / Ford 2000 3 cylinder lift problem #1
Cwj5746
Douglasville ga
1966 ford 2000
I have 1966 ford 2000, the lift will raise when you crank the tractor and stay, I have no control on the lift.The only way to lower the lift is to loosen the bolt under the seat, to let the pressure off, squirts oil as I do this. The lift has worked normal, I did notice a chattering noise the last couple of times using the tractor,however the lift was working.The oil is brownish to slightly milky.Any ideas?
   / Ford 2000 3 cylinder lift problem #2
Sounds like a valve is stuck. Be sure the filter is clean. You'll probably have to remove the seat, take out all the bolts around the perimeter of the hydraulic controls cover, disconnect the rock shafts from the 3 point hitch, carefully remove the cover, turn it over and be sure the valve is free to move in and out. Best that you let a qualified mechanic do this.
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2017 INTERNATIONAL PRO STAR SERIES SLEEPER (A50854)
2017 INTERNATIONAL...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
