I think I may have gotten past the stalling, but I'm having trouble determining what happened. Symptoms/Chronology:
1. I had decided to go to a heavier oil 15w-40, verus 10w-30, in part due to a knocking sound that I was having a mechanically inclined acquantance evaluate.
2. Drained the old oil night before, intending to look for metal, or other clues in oil. Small amounts of moisture had been observed, mainly after tractor sat for months.
3. Next day, filled crankcase with 15w-40, started engine, oil light stayed on and engine stalled after maybe 30 to 45 seconds. Unusual vapor/smoke expelled from crankcase, not heavy, but observable.
4. Pulled oil filter, turned engine over, and after hesitation, observed strong pumping action.
5. Replaced filter, started engine, oil pressure light goes off, engine runs normally.
In summary, it may no longer have a significant problem, but I am puzzled:
1- Can an oil pump lose prime? I understand the "floating shaft" can be displaced, but if that was the case, would I not still have a problem? Thicker oil, leaving it empty overnight????
2- Could the lack of oil pressure (oil light on), cause the engine to stall, as if fuel starved? Almost like a "safe mode" shut down, but a 1971 model 2000 didn't have such a feature, did it?
Thanks for ideas, I'm just trying to learn and be smart(er).
