Ford 1920 Starter motor problem
   / Ford 1920 Starter motor problem #1
ArcticFord
Norway
Ferguson TEA20 / Ford 1920
Hi !
Some years I sold my Shibaura 1540.
Ok, but new tractor. This time a Ford 1920. Shibaura production.
Starter motor will not crank the engine. It spins inn but no futher action. Have to click 10 - 15 times before engine turn. When engine hot, no problem starting it.
Direct 12V connectors failing ?
   / Ford 1920 Starter motor problem #2
Hi !
Can't help with your starting problem, but I love my Ford 1920, and am sure you will too.
   / Ford 1920 Starter motor problem #3
Hi !
Take out negative lead that is attached to the frame, check for rust, wire brush and put back. Look at the connection at the starter for sign of corrosion. Clean and put thing back how you found them. Start and report and report back.
JC,
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
KSI Conveyor (A52748)
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
