Ford 1920 Starter motor problem
   / Ford 1920 Starter motor problem #1
ArcticFord
Member
Norway
Ferguson TEA20 / Ford 1920
Hi !
Some years I sold my Shibaura 1540.
Ok, but new tractor. This time a Ford 1920. Shibaura production.
Starter motor will not crank the engine. It spins inn but no futher action. Have to click 10 - 15 times before engine turn. When engine hot, no problem starting it.
Direct 12V connectors failing ?
   / Ford 1920 Starter motor problem #2
Hi !
Can't help with your starting problem, but I love my Ford 1920, and am sure you will too.
   / Ford 1920 Starter motor problem #3
Hi !
Take out negative lead that is attached to the frame, check for rust, wire brush and put back. Look at the connection at the starter for sign of corrosion. Clean and put thing back how you found them. Start and report and report back.
JC,
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
3 FORKS (A56857)
3 FORKS (A56857)
