Ford 1920 engine quits after running short time
   / Ford 1920 engine quits after running short time #1
jab-law
I have a real nice 1987 Ford 192o diesel. Lately it has been seizing up after running a short time under heavy load. My guess was that it was over-heating, so I replace water pump -- and it is still seizing up. It will start right up after cooling, so I'm pretty sure that it is an over-heating problem -- but not positive.
I have not changed the thermostat, so that is my next chore (I should have done it first -- cheaper and easier). I will probably just go to local parts store and get similar thermostat at 190 degrees and some gasket paper, as pre-cut gasket seems hard to come by.
Any other ideas on what I should be looking for? It does not seem to be fuel or air, as engine will not even turn over after stalling until it cools down -- then it fires right up. so I am guessing engine is over heating, then freezing up.
What else would casue this besides bad thermostat? Radiator is getting hot, but not overly so. what else should I by checking or looking for??
thanks.
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2017 MORBARK BEEVER M12RX PORTABLE WOOD CHIPPER (A51247)
2017 MORBARK...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
2013 RAM 4500 (A50323)
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
