Ford 1920 - debris fell in hydraulic reservoir
   / Ford 1920 - debris fell in hydraulic reservoir #1
gfxeditor
Ford 1920
I was poking around the back of my 1990 ford 1920, and removed the hydraulic reservoir cap but didn't see that there was a half a maple seed / helicopter sitting behind the cap. As soon as i removed it, the seed fell in and disappeared. I tried fishing it out and vacuuming to see if it would come back up but so far no luck.
I'm not terribly mechanical. Is there a way to access the area to clean that out? How bad a problem can this cause? Any advice welcomed! Thanks!
   / Ford 1920 - debris fell in hydraulic reservoir #3
What 5030 says. Forget about it but learn from this experience.
   / Ford 1920 - debris fell in hydraulic reservoir #4
don't worry about it you will get it out next hydraulic fluid change. if your tractor has a strainer it will catch it before it goes into the pump. a maple seed is soft and would not cause damage even if it got into the pump. If you had dropped a rock or something hard might be a different story.
   / Ford 1920 - debris fell in hydraulic reservoir #5
I had a 1900 and it had a suction (sump) screen in the side of the transmission under a three bolt cover. Mine would pick up various things. Not sure if yours as one but if you looked at a parts book you could find out.
No big deal and I agree with the others on no harm done.
   / Ford 1920 - debris fell in hydraulic reservoir #6
Even if it makes it to the gear pump it will be chewed to pieces.
   / Ford 1920 - debris fell in hydraulic reservoir #7
If it's like my gutters, you'll have little maple trees growing out the oil filler hole in about 2 weeks.
LOL. thanks for the comments and the peace of mind you guys. Glad it's not going to clog things up. Will definitely exercise more caution when opening things up next time.
I looked over the repair manual but I couldn't understand much of what i was looking at.
I'll take a look at accessing the screen pre filter. Wouldn't hurt to clean that out to avoid reduced flow imagine.
Appreciate your help everyone!
   / Ford 1920 - debris fell in hydraulic reservoir #9
Remember, not totally sure you have one. Some do and some don't and my 1900 did. If you do, it's under a 3 bolt circular cover on teh side of the transmission. If you have one, it uses a thin paper gasket.
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
