Ford 1920 - Clutch and Noise Issues
   / Ford 1920 - Clutch and Noise Issues #1
RDFarm
Goshen, AR
Ford 1920
Long time reader, but first time for a question on here... Hopefully you all can help me out.
So here is the background. I'm dealing with a '94 Ford 1920 SSS. The clutch is going out I know (PO said it had been fully adjusted out and lowered the price by the amount of the repairs when I bought it), but have been able to run it pretty hard for 2 years without it finally quitting. It's got 3400 hours on it and I don't know a lot about the previous maintenence that has been performed. I'll be ripping into the clutch since all repair places I've been want $2K in labor to replace it.... Big question I have is, just recently I've noticed a "thunking" somewhere in the rear end of the tractor... It's rythmic with the speed of the engine, only when the clutch is engaged. When the clutch is disengaged it disappears. Also, it seems that the tractor is "dragging" and not as free rolling of late but hasnt seems to hamper the power. Where do I need to be looking to identify this? My gut feeling is a bearing going south... Which in my experience can be quick and damaging/expensive if it does actually go. Does this have anything to do with the clutch slowly going or am I correct in my assumptions? Any suggestions are much appreciated.
Dustin
   / Ford 1920 - Clutch and Noise Issues #2
Could be the release bearing making noise. You'll be changing that anyway when you do the clutch. Does it make the noise in neutral with the clutch out? If so that points even more to release bearing. Lots of other moving parts further back, hopefully none of those are the problem.
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
