Ford 1920 blowing black smoke
   / Ford 1920 blowing black smoke #1
double hunter
Ford 1715
Looking at buying a Ford 1920, it is blowing black smoke out of the exhaust and the valve cover tube, the owner said it started all at once and also experienced a loss in power, he has it priced cheap, any ideas as what to llok for, sounds like a fuel problem, can't decide whether to jump into this project or not, any advice appreciated.
   / Ford 1920 blowing black smoke #2
It probably started all at once when it was stuck up to it’s axles in mud. I believe this engine was over stressed.
Blowing black smoke out of the exhaust is usually serviceable by replacing the injector, but black smoke out of the valve covers indicates a serious problem. Black smoke from the valve covers could indicate broken rings.
You’re definitely looking at engine work in excess of $2000. If it was a cheap fix, he would have fixed it.
Mike
I'm thinking the same thing, havn't really decided to jump on this, it is a 4 wheel dr and he wants 1k for it, have no idea what it would cost t have the engine overhauled.
   / Ford 1920 blowing black smoke #4
for 1k$, I would do it for the fun of it.
If the transmission is good, I would take the risk.
Chris
   / Ford 1920 blowing black smoke #5
ditto.. 1k$ and you can repalce the engine entirely and still come out.
   / Ford 1920 blowing black smoke #6
If you can not fix it you could part it out and and make a good proffit.
Bill
   / Ford 1920 blowing black smoke #7
he should be able to fix it. me and a puddy put a new piston in a 1920 earlier this year.. cleaned up the aluminum off the cyl wall.. new bearigs and rings. machine is mowing again.. oh yeah.. fixed his water leak that caused it too! :) 700$ in parts and gaskets...
   / Ford 1920 blowing black smoke #8
I think I'd buy it and then do a quick compression check after removing the injectors. That will probably tell you all you need to know. It could be something as simple as a burned valve and leakage around the stem, but I'd think those symptoms point to a broken ring or a hole in a piston.
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
2004 INTERNATIONAL 4300 BOX TRUCK (A53426)
2004 INTERNATIONAL...
12in Auger Mini Skid Steer Attachment (A51691)
12in Auger Mini...
