FORD 1920 3pt. oscilates up/down
   / FORD 1920 3pt. oscilates up/down #1
auctioneeral
shamong,NJ
KUBOTA B26TLB
ford 1920 3pt. hickups,oscilates up and down. After reading posts on here, It sounds like it maybe the lift piston seals.
Does anybody have service manual were they could send me pages of the detail of the 3pt lift piston. I have found online
drawing of lift piston area of part numbers. But I have not yet started to tear it apart yet.
   / FORD 1920 3pt. oscilates up/down #3
I'm going with piston seals. There's no mystery in there. Just start unbolting it. On my 3910 the unit was heavy enough that I used a cherry picker to install it after cylinder repair.
   / FORD 1920 3pt. oscilates up/down #4
See if this attachment helps.
  • NH1920 HydLiftHousing.pdf
Great information thanks
Question on parts look up.
Do I need to order
#16 seal protector
#16A O-ring
#16B ring backup
plus #18 gasket.
   / FORD 1920 3pt. oscilates up/down #6
Service manual says replace all O rings and seals so I would get the rocker arm rings and seals also.
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
