Ford 1920 2 stage clutch adjustment
   / Ford 1920 2 stage clutch adjustment #1
Highvoltage
Ford 1920
I have a ford model 1920 . I had to split the tractor to work on the transmission,while I had it in half I decided to replace the 2 stage clutch and assembly in hopes it makes it until I am to old to care . I installed it and the manual says to torque the 6 bolts to 16-20 lbs. ft. I try to do as it says and the bolts bottom out on flywheel. It goes on how to adjust a existing clutch by using the 3 adjustment Bolts and getting a gap of .95mm which I did but when I try to torque the 6 bolts to what they call for the bottom out before they get to torque. Can someone help me ? I tried to add pictures but this is not iPhone friendly and I am not computer literate��
   / Ford 1920 2 stage clutch adjustment #2
I'm needing help adjusting clutch on my 1920 Ford tractor
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2803 (A50460)
2803 (A50460)
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
2012 John Deere 7230R (A52748)
2012 John Deere...
