Ford 1910 glow plugs
   / Ford 1910 glow plugs #1
carlyla
My Ford 1910 has always needed 20 seconds of pre-heat to start and this has always unsured a prompt start. Until this week! I noticed the engine turning over quite a few times before it would start even with the pre heat. The check wire on the dashboard still glows hot and I have taken the aluminium contact strip and the glow plugs out to clean all the electrical connections with a wire brush and a knife. Having put the glow plugs back I noticed the the closest one to the electrical connection always got hot, the middle one got hot after I cleaned the contacts and the end one at the front of the tractor didn't get hot at all. I tried the front end glow plug in the first position (nearest the electrical conection and seat) and the plug got hot which suggests that the plugs are ok but but the electrical current is not - but I can't think what else I can do to isolate and fix the problem. The tractors starts instantly when the engine is hot from work but still labours for ages without firing when cold before finally firing into life - sometimes with a second burst of pre heat for 10 seconds in addition to the original 25 seconds.
Any ideas greatly appreciated.
   / Ford 1910 glow plugs #2
when looking at glow plug end that heat up make sure none seem to flared out or have what appears to be type of carbon build up on them. also somewhere on your tractor you will find a glow plug relay. in many cases it will look like a ford fender mount solenoid but much more heavy duty but in a pinch the old ford solenoid will work. hope this helps.
mitch becton
72in Large Capacity Bucket (A49251)
72in Large...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2017 Ford F-250...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
3pt Seat for Tractor (A49251)
3pt Seat for...
Skid Steer Hydraulic Adjustable Pallet Forks (A47371)
Skid Steer...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A48081)
Unused 2025 40ft...
