Ford 1910 4x4 front end locked up, looking for advice
   / Ford 1910 4x4 front end locked up, looking for advice #1
machfabwelder
Orange, MA
Mahindra 4025
Hi All, I checked the search and didn't see my issue.
My ford 1910 front end was locked up in and out of 4wd. If I lift the front off the ground the front tires spin free in opposite directions.
I have the repair manual and it seems to me that the spider shaft pin is broken and the pin slid out, I had that happen in a truck before.
My question is can I pull the outer drive and axle tube off in one piece? I don't see a clip on the inner axle spline. :p
   / Ford 1910 4x4 front end locked up, looking for advice #2
It does sound like the ring and pinion might have locked up. Yes you can take the axle shaft and tube out.
   / Ford 1910 4x4 front end locked up, looking for advice #3
I would remove the drive shaft and see if it is the front axle locked or the trans. Will the tractor move and slide the front wheels in 2wd. What were you doing when this problem started.
Bill
John Deere 72in Grapple (A49251)
John Deere 72in...
More info coming soon! (A48081)
More info coming...
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A46684)
2018 Ford F-150...
Pro Armour Rims and Tires (A49339)
Pro Armour Rims...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
