ford 1900 turn key and all it does is thump once
   / ford 1900 turn key and all it does is thump once #1
jameshust
ford 1900
:confused: I have had this 1900 sitting for about a year. I decided to get it up and running again. I replaced all fluids and cleaned everything out and up. hooked up a new battery and tried to start it up. It would not turn and made a thump sound... I looked in the peep hole located on the clutch side of the tractor, only to find rusty wet stalactites. My question is. Am I in trouble, and i what should i do next??
james
   / ford 1900 turn key and all it does is thump once #2
Try turning it over by hand to make sure your not fighting a lockup.
   / ford 1900 turn key and all it does is thump once #3
Welcome to TBN. Make sure the trans is in neutral. Roll the tractor a little to make sure.If that is ok, Try turning the engine manually with a socket on the front of the crank. Make several revolutions. If it wont turn then I would remove the injectors and try turning the engine over manually.If there is any fluids in the cylinders this will pump it out. After you get it to turn over manually the try with the starter. If it isn't in a warm area I wouldn't do anything untill I thawed it out.
Bill
   / ford 1900 turn key and all it does is thump once #4
By your description I am thinking it falls in line with a discussion here a few days ago on storing your tractor with the clutch blocked in the depressed position to keep it from rusting to the flywheel. You may try blocking the clutch down and putting it in gear then rocking it back and forth or just try dragging it forward and back to break it free. If it has only been setting a year, then it is unlikely that the engine would be frozen up, but anything is possible.
   / ford 1900 turn key and all it does is thump once #5
Oh, if it moves freely with the clutch depressed and in gear, then it is not the clutch frozen to the flywheel and is likely the pistons frozen to the block, then you would need to get some lubricant to the top of the pistons like liquid wrench or WD 40 and let it set for several hours and try to rock the tractor back an forth or turn the crank with a wrench working it back and forth till if is moving freely. Then you can try your starter again.
   / ford 1900 turn key and all it does is thump once #6
Could easily be a bad battery cable or dirty/loose battery cable end connection. Bad connection between the starter solenoid and the starter itself. A stuck clutch isn't going to cause the problem if the transmission is in neutral when the start is attempted. It is unlikely that your engine is seized. Stick a bar in the inspection hole and bar the flywheel over to prove the engine is free. Then go to work on the electrical.
   / ford 1900 turn key and all it does is thump once #7
When first turning any engine with the potential to have liquid in a cylinder turn it backwards toward an open exhaust valve to give the liquid a place to go. This is done commonly in light aircraft that have gravity fuel systems & horizontal cylinders. MikeD74T
thanks everyone for your expertise. I have hand turned the engine and bared the flywheel,as suggested. The flywheel was rusted pretty bad. well, with that said. I am still getting the thump when i try to turn the enigine over. I took the starter out and will get it tested. other than that, I have no clue what it might be....... any suggestions would be much appreciated.. thanks
   / ford 1900 turn key and all it does is thump once #9
Will the engine turn over by hand.
yes, the engine turns over by hand.
Kubota L35 4WD Tractor Loader Backhoe (A49461)
Kubota L35 4WD...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2011 Kubota M7040SUD 68HP 4WD Utility Loader Tractor (A49461)
2011 Kubota...
