Ford 1900 pto grinding
   / Ford 1900 pto grinding #1
Mount Airy NC
ford 1900
I just bought a Ford 1900 2wd with a loader. The tractor is tight and runs great so far. The only issue I have is when I hooked to the bush hog and attempt to engage the pto it grinds like nobodys business.
This is done with the tractor at an idle, clutch depressed and transmission in neutral. The only way I can get it to engage without forcing it in gear is to kill the engine, engage it and then fire it up. It mows fine and everything seems to work well after it fires up. Any ideas?
I have been around tractors all my life, but this is the first one I owned, I know it not a high end tractor, buts it what I could afford and it does what I need it for.
   / Ford 1900 pto grinding #2
SOunds like the clutch, have you tried adjusting it?
I did see that someone did post a picture on another similar topic, but it was not real clear.
2012 International 4300 Reefer Truck (A53472)
2012 International...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2014 Ford Escape (MPV), VIN # 1FMCU0JX0EUB93016 (A51572)
2014 Ford Escape...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
300 GALLON PORTABLE FUEL TANK (A51247)
300 GALLON...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
