Ford 1900 low oil pressure
   / Ford 1900 low oil pressure #1
Charliej
Superior, Wisconsin
Ford 1900
Just completed a rebuild of a Ford 1900 (3 cylinder Shibaura diesel). Upon startup I have very low oil pressure. About 4 psi at high idle. I took the tractor back apart and checked the pickup tube, pressure releif valve, and everything else I could think of. I determined it must be the oil pump so I bought a new oil pump and installed. However after putting it back together I still have low pressure. What else am I missing that could be causing this? During the rebuild I replaced all bearings and seals, rings, etc. There are no visible leaks anywhere. Is there something that I missed putting back in that could be causing an internal oil leak? Any advice would be much appreciated.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2013 John Deere 824K (A53472)
2013 John Deere...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
Ford 345C Tractor with Loader (A51573)
Ford 345C Tractor...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
