Ford 1900 injector pump oil
   / Ford 1900 injector pump oil #1
Dresding
Branchport NY
IH-H, IH-444, Ford 1900, IH-C IH-360
I have a Ford 1900 and no manual.
What oil is used in the "Oil Plug" fill on the injector pump?
This is the first injector pump I've seen that has an oil cap on it!
   / Ford 1900 injector pump oil #2
Typically injection pumps with self contained oil reservoirs will take motor oil(whatever the engine takes) and should be changed when engine oil is changed. There will be a drain plug on the bottom and a level plug about a third the way up on the side of the pump housing.
   / Ford 1900 injector pump oil #3
common on inline pumps or non fuel lubed pumps like the rotary used on some fords.. etc.
put crankcase oil in there. like 15w40 c rated.. etc.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
1996 CHEVROLET CAPRICE SEDAN (A52576)
1996 CHEVROLET...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
