ford 1900 injection pump help
   / ford 1900 injection pump help #11
I've run my 1900 out of fuel a couple of times in the 10 years I've owned it. And it's a real PIA to get going again cause these things do not like air in the system. I'd bet like others have mentioned you are drawing air in somewhere. And I would suspect a stripped bleeding screw on top of the fuel filter asm (which is $300 to replace). Mine is messed up and I've just sealed a bolt into position there and if I need to bleed it I'll take the line off first !
Steve
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2015 DODGE RAM...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2008 CAT 287C (A50854)
