Ford 1900 Hydraulics issue
   / Ford 1900 Hydraulics issue #1
SnowedIn
New Hartford, NY
Simplicity Legacy XL, Ford 1900
Hi Guys,
I recently bought a 1981 Ford 1900. The power steering and three point hitch were not working; the seller said most likely a clogged screen. So I drained the hydraulic oil. It looked terrible. Milky light brown in color, it reminded me of Thanksgiving gravy. I pulled the hydraulic screen and it was certainly dirty/clogged. I cleaned it thoroughly with diesel fuel. Prior to reinstalling it, I took a rag and with a few fingers wiped inside the cavity where the screen goes. It is basically the area where the differential and other drive gear stuff is. I was able to mop up some very thick black oil-like substance. Is this indicative of some bigger problem? Is it possible that some engine oil is seeping into the crankcase? Before I reassemble everything and pour $150 worth of hydraulic fluid (type 134) into it, maybe I need to do some further work. Any suggestions? I hope the hydraulic pump isn't shot. I was told it was replaced 4 years ago.
I know it has been a while since I last posted, but I sure enjoy all the info here.
Thanks much.
Cap
   / Ford 1900 Hydraulics issue #2
I would dump in 5 gallons of diesel fuel and rock the tractor back and forth with out starting it to get it to slosh around good,
then dump that see what it looks like.
LouNy,
I took your advice and got the sludge out. I reinstalled the screen and bingo!! The hydraulics work perfectly. Thanks much.
Cap
   / Ford 1900 Hydraulics issue #4
Your welcome, good luck with the tractor.
2016 GMC Savana (A50120)
2016 GMC Savana...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
