Ford 1900 Hydraulic bucket raises unevenly
   / Ford 1900 Hydraulic bucket raises unevenly #1
markrose
Escananba, MI
Farmall A, Ford 1900
How do I insure the hydraulic cylinders actuate equally raising the bucket evenly?
   / Ford 1900 Hydraulic bucket raises unevenly #2
Which ever cyl has the least resistance will move first.
One cyl might be leaking.
You can do a cyl load test by disconnecting the hoses from one cyl if you have two, and cap or plug the hoses.
Then remove the hose from the base end of the test cyl and then try and retract more.
You are checking to see if fluid comes out of the base end port.
If it does, that cyl is bypassing and you need new seals.
Then check the other cyl.
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
(1) DBL DOOR REFRIGERATOR (1) VISSANI REFRIGERATOR (A51248)
(1) DBL DOOR...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
