Ford 1900 Hydraulic bucket raises unevenly
   / Ford 1900 Hydraulic bucket raises unevenly #1
markrose
Escananba, MI
Farmall A, Ford 1900
How do I insure the hydraulic cylinders actuate equally raising the bucket evenly?
   / Ford 1900 Hydraulic bucket raises unevenly #2
Which ever cyl has the least resistance will move first.
One cyl might be leaking.
You can do a cyl load test by disconnecting the hoses from one cyl if you have two, and cap or plug the hoses.
Then remove the hose from the base end of the test cyl and then try and retract more.
You are checking to see if fluid comes out of the base end port.
If it does, that cyl is bypassing and you need new seals.
Then check the other cyl.
Portable Cattle Loading Shute (A50515)
Portable Cattle...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
