Ford 1900 4x4 front knuckle bushings replacement
   / Ford 1900 4x4 front knuckle bushings replacement #1
honkerone
I had to replace bearings in front axle 4x4 and wanted to replace bushing in knuckle since I was so close to them, I made a tool that would fit the inside diameter and the outside diameter to try to knock them out, no luck I have been working on the top one which is bigger, and have had no luck to get it to move, hate to hammer it very hard, scared I may break the casting axle knckle housing. Any information would be much appreciated. Joe
   / Ford 1900 4x4 front knuckle bushings replacement #2
I have 2 different ways I do it. Take a hack saw blade and cut the length of the bushing. This will releive the press fit and drive it out. I have a bushing splitter for the air hammer that works well if you have the room to use it. You just have to be carefull not to gouge the housing bore.
Bill
Thanks Bill, I got them out.
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
