Ford 1900 2wd transmission fluid
   / Ford 1900 2wd transmission fluid #1
scubaskb
Ford 1900 2 wd
It is time to service our Ford 1900 2wd. With no manual or service tech on island I have come to you. What grade of fluid is recommended and how much?
I put in 85w90 with very poor results. Now I need your help before I destroy my old machine.
Thank you
Mike
   / Ford 1900 2wd transmission fluid #2
The recommended fluid for the Shibura built 1900 is the Ford 134 fluid. Quite a bit thinner than 80W-90 :D
I&T shop manual is FO-44
now the hard part of finding this on St. Kitts and Nevis
   / Ford 1900 2wd transmission fluid #4
I use UTHF in my 1900. Walmart,Farm and Fleet. TSC or any one who caters to farm supplys should have it.
Bill
   / Ford 1900 2wd transmission fluid #5
google fo-44 and you will get several hits. I would think you can find a supplier to send you one. If tech help is not close by, it will be a valuable tool.
   / Ford 1900 2wd transmission fluid #6
get rid of the gear oil before you cavitate the pump.
hit a walmart or similar if you have them.. and get some utf oil meeting the M2C134 spec.
soundguy
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
19103 (A51694)
19103 (A51694)
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
