Ford 1720
   / Ford 1720 #1
JTL
Hi,
I've got a line on a ford 1720, 28hp tractor and I'm wondering about it's ability to plow a field. Doe it have enough jam to pull a plow?
I've only got about 5 acres to plow and once I've managed to reseed it its not going to be used for much harder work than plowing snow and running a brush hog.
Thanks for the answers
Aaron
   / Ford 1720 #3
I have a Ford 1700 4x4 which is an earilier model of a 1720. Specs still look the same.
Attachments available for my 1700 printed in an accessory manual:
soil breaking: #101, 2 bottom plow 14 or 16 inch.
My thoughts only, depending on the type of soil, if sandy bottom you may be able to use the 16". If hard soil not worked up much use the 14". You won't get a lot of speed but it will work. Five acres will take a while. Plan on a whole day or more.
I have a full list of Ford recommended equipment if you need more information such as sizes that will work on this tractor.
#105 rotary tiller 48 HD or 54 HD inch
#952 rotaty mower up to 60"
   / Ford 1720
Thanks guys
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
