Ford 1720 vs. Kubota L3010
   / Ford 1720 vs. Kubota L3010 #1
MMH
Murrysville, PA
JD 4500
Looking for a tractor for clearing & excavation work. Found a 1720 w/ a FEL & backhoe. I'm a little more familiar w/ Kubotas so I wanted to know how this tractor would compare to a L series. Size wise, robustness wise, etc.
Initially, the tractor will be used more for TLB work. After I get the addition built & property where I want it, I would probably be better served w/ a compact tractor. I assume all standard category I implements. Is the PTO live?
The backhoe is New Holland subframe mounted unit. How difficult is it to remove the backhoe?
Thanks.
   / Ford 1720 vs. Kubota L3010 #2
They are very competitive as far as size just the ford is a little older and just a little shy on all the spec's when comparing the two.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
Makinex Power Lifter (A52377)
Makinex Power...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53472)
Gooseneck...
2012 Hyundai Sonata (A51694)
2012 Hyundai...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
