Ford 1720 vs. Kubota L3010
   / Ford 1720 vs. Kubota L3010 #1
MMH
Murrysville, PA
JD 4500
Looking for a tractor for clearing & excavation work. Found a 1720 w/ a FEL & backhoe. I'm a little more familiar w/ Kubotas so I wanted to know how this tractor would compare to a L series. Size wise, robustness wise, etc.
Initially, the tractor will be used more for TLB work. After I get the addition built & property where I want it, I would probably be better served w/ a compact tractor. I assume all standard category I implements. Is the PTO live?
The backhoe is New Holland subframe mounted unit. How difficult is it to remove the backhoe?
Thanks.
   / Ford 1720 vs. Kubota L3010 #2
They are very competitive as far as size just the ford is a little older and just a little shy on all the spec's when comparing the two.
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2016 Freightliner Tandem Bucket Truck, VIN # 1FVHCYCYXGHHA5025 (A51572)
2016 Freightliner...
