ford 1720 stuck in mud
/ ford 1720 stuck in mud #1
mr4shootin
Florida
Ford 1720 4wd shuttle
Picked up my tractor on the way to hunting lease last Thursday and I had it stuck by noon Saturday.I got in to a small area of high ground (surrounded by swamp) where I mowed between a few white oaks to put up a bow stand.On the way out the bush hog was dragging a little and I bogged down.The guy I bought the tractor from had the three point mounted in the lowest position where it wouldn't raise very high off the ground.We didn't want to risk getting the truck stuck too, so here is how we got it out.I moved the linkage to the top hole, then disconnected the top link and used a big ratchet strap around the rops to lift the bush hog a little.Went to town and after seven stops and about 40 miles we found a high lift jack.(Most people we asked didn't know what a high lift jack was).I can tell you it is worth every bit of the 80 bucks I paid for it.Any way to make a long story longer we cut some 4x4 post and used the jack to get them under the front tires then used the jack to winch the tractor out.See pics below.
The tractor is 4wd drive but the tires don't have a lot of traction.The last pic is tractor safely back at camp and cleaned up.I am working on a bumper and grill guard for it.Will post pics later.
/ ford 1720 stuck in mud #2
Something to keep in mind for the next time, you know there will be one..., cut a couple 4"-5" diameter poles about 16-20" longer than the tire diameter & lash to the outside of each tire. You'll come out of a hole like that in leaps & bounds. MikeD74T
/ ford 1720 stuck in mud #3
I got stuck like that one time. I detached the bush hog and the tractor came out much easier. Then I got on solid ground and attached a tow chain to the hog and pulled it out of the bog. It was a lot of work but, it worked.
/ ford 1720 stuck in mud #4
Darn turf tires anyway....... just usless in a bit of mud aren't they? :D :D :D
R1's require a different set of wheels.My local New Holland dealer quoted me a price of $1440.00 for the set, tires not included.:(:D
We thought about trying that but it was so far to solid ground I didn't think I would be able to retrieve the bush hog.
/ ford 1720 stuck in mud #7
I was just kidding....... I doubt that R-1's would have helped you much there anyway. Actually I'm thinking of switching from the R-4's on mine to turfs.
/ ford 1720 stuck in mud #8
I did something like that once during rainy season with my 1910. R1's didn't help. My farmer neighbors International did the trick.
/ ford 1720 stuck in mud #9
You should call him up and thank him for that. If the cutter was able to raise higher, you would have been that much deeper.
/ ford 1720 stuck in mud #11
That ground looks pretty wet, not sure what tire would work. Cheaper than a new set of rims and rubber - why not put chains on it?
Or tracks!:D
/ ford 1720 stuck in mud #12
you get a big +1 for posting pictures without us having to ask.. LOL
Glad you made it out ok..
Brian
/ ford 1720 stuck in mud #13
On my old Handyman jack there's a hole under the lift arm. I have a grab link for 3/8" chain pinned into it, and it's great for just what your pic shows. Used that jack many times over the last 40 years, thankfully less lately!
Jim
Jim
I'll have to look and see if mine has that hole as it was a real pain to hold the jack and the chain tight and try to crank the handle.Thanks for the idea.
Brian
Yeah.:D I've seen the "This thread is worthless without pics" enough times to know better.I now try to keep a little camera with me at all times for capturing the moment.
/ ford 1720 stuck in mud #16
Fellow you are some kind of lucky your tractor did not sink out of sight. There is no way I would have chanced going thru that.
Glad it worked out for you.
/ ford 1720 stuck in mud #17
You guys deserve the Darwin award for hooking up that jack like that in your pictures........
Not to be critical, but that really isn't a good practice. Get the right tools for the job and it will be accomplished quickly and safely.
Craig
/ ford 1720 stuck in mud #18
Darwin award what Ya mean!!! This is one of the designed uses of the jack, to be used as a winch. Only problem is the attachment of the chain. They have redesigned the way the chain is attached in the new "original high lift" jack so that you should use the "off road kit" for chain attachment. Use this link for a video of its use...YouTube - Hi-Lift Off-Road Kit. Many of the non "original Hi-Lift" jacks still provide a hole in the lift hook for a clevis. I have been recently been checking the various manufactures since I need to use my Father-in-laws this weekend!
Jeff
/ ford 1720 stuck in mud #19
I've winched a lot of stuck stuff out with a Handyman/High Lift jack, but I gotta agree with Shmudda - a comealong is lots easier and quicker. If I were going into back land I'd have both. You can unstick lots of vehicles by jacking up and pushing off the jack sideways so the tires get a fresh piece of mother earth to sit on. That's not recommended either, but it sure works. Or running the jack at 45 degrees hooked under a spring shackle or trailer hitch or some such. Same goal, get the vehicle onto fresh ground.
Two good tools, sometimes you need both.
Jim
/ ford 1720 stuck in mud #20
Gimme a winch anyday. Even a 3000lb winch with about three small snatch blocks will do wonders if you have battery power.
We also used to chain a log across both tires at the rear, then reverse until the tractor was sitting up on the log but its impossible with an implement on and tricky at the best of times...
