Ford 1720 rear axle seal
   / Ford 1720 rear axle seal #1
wv1720
West Bygolly
Ford 1720
Hello, I need to replace the rear axle seal on my 1720. From the parts breakdown, it looks like I need to remove the wheel shaft case, remove the nut from the end of the axle, pull the axle out, replace the seal then put everything back together. Does this sound about right? Are there any tricky things I need to be careful of? Looks fairly straight forward, I have medium mechanical skills and tools. Just don't want to get it taken apart then run into problems.
Thanks for any advice.
   / Ford 1720 rear axle seal #3
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
1013 (A51573)
1013 (A51573)
2011 Kubota KX080-3 Midi Excavator (A50322)
2011 Kubota...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
