Ford 1720 HydraulicTransmission Fluid
   / Ford 1720 HydraulicTransmission Fluid #1
cabot70
Goldsboro, NC
Ford 1720
I have a Ford 1720, what type of hydraulic/transmission fluid does it use?
   / Ford 1720 HydraulicTransmission Fluid #2
Quoting my Ford I&T Service Manual (FO-46) for a nonsynchromesh 12 X 4 gear transmission, model 1720; "The transmission housing and rear axle center housing serve as a common reservoir for gear lubricant and oil for the hydraulic system. The oil should be drained and refilled with Ford 134 oil or equivalent lubricant every 300 hours of operation". You can use Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid as it meets the Ford New Holland ESN-M2C134-D requirements Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid - Walmart.com
   / Ford 1720 HydraulicTransmission Fluid #3
:welcome:
To the forum from Alabama.
   / Ford 1720 HydraulicTransmission Fluid #4
yep, UTF fluid meeting the m2c134d specs.
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
