Ford 1720 HydraulicTransmission Fluid
   / Ford 1720 HydraulicTransmission Fluid #1
cabot70
Goldsboro, NC
Ford 1720
I have a Ford 1720, what type of hydraulic/transmission fluid does it use?
   / Ford 1720 HydraulicTransmission Fluid #2
Quoting my Ford I&T Service Manual (FO-46) for a nonsynchromesh 12 X 4 gear transmission, model 1720; "The transmission housing and rear axle center housing serve as a common reservoir for gear lubricant and oil for the hydraulic system. The oil should be drained and refilled with Ford 134 oil or equivalent lubricant every 300 hours of operation". You can use Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid as it meets the Ford New Holland ESN-M2C134-D requirements Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid - Walmart.com
   / Ford 1720 HydraulicTransmission Fluid #3
:welcome:
To the forum from Alabama.
   / Ford 1720 HydraulicTransmission Fluid #4
yep, UTF fluid meeting the m2c134d specs.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2003 HEIL KILL TRAILER (A52472)
2003 HEIL KILL...
