Ford 1720 buying help
   / Ford 1720 buying help #1
Ihatethewinter
Montdale,pa
Ford 9n
Hey guys newbe here. I'm looking to buy my first 4wd tractor and I was looking at a ford 1720. They guy wants $4200. BUT. The pto makes some kind of noise when it is engaged and it has 6000 hrs. I'm not too concerned with the pto but I'm hesitant on the hours. Is that too many hours? What is the life expectancy on these?
   / Ford 1720 buying help #2
Good Afternoon Ihatethewinter,
Welcome to TBN !
6000 hrs is quite a bit but if it was taken care of it should still have a descent amount of life left. My MF 1040 is about the same age and I only have a third of those hours on my machine.
I would suggest that you find someone more knowledgable than yourself to look at this machine, and give it a good evaluation, listen to the PTO noise, possibly a bearing. The $4200 sounds high to me with those hours.
Things that you want to look at are the general overall condition of the tractor, does it look like it was taken care of etc.
Here is a link to that machine on Tractor Data
TractorData.com - information on all makes and models of tractors
Tractors > Ford > 1720
Tractors:
-Farm Tractors
-Lawn Tractors
-Compare tractors
-Brand search:
Classifieds
-Tractors for sale
-Place free ad
Sections:
-Articles/News
-Tractor Shows
-Store
-Contact
eBay Marketplace Logo
SBA185366060 New Ford Compact Tractor Gl ...
$17.99 56m
Ford 1120/1220/1320/1520/1720 Tractor Pa ...
$130.00 1h 31m
12V Starter 1710 1715 1720 1725 1925 For ...
$80.53 5h 49m
View all disclaimer
Ford 1720
Ford 1720 tractor photo
1987 - 2000 Twenty Compact Series
Compact Utility tractor
Previous model: Ford 1710
Next model: New Holland 1720
Larger: Ford 1920
Smaller: Ford 1520
Overview
Engine
Transmission
Dimensions
Photos
Production:
Distributor: Ford
Manufacturer: Shibaura
Factory: Japan
Original price (USD): $14,000 (2000)
Ford 1720 Engines:
Shibaura 1.5L 3-cyl diesel
Shibaura 1.4L 3-cyl diesel
full engine details ...
Capacity:
Fuel: 8.5 gal [32.2 L]
Hydraulic system: 7.1 gal [26.9 L]
3-Point Hitch:
Rear Type: I
Control: draft control optional
Rear lift (at 24"/610mm): 1742 lbs [790 kg]
Power Take-off (PTO):
Rear PTO: transmission
live (optional)
Rear RPM: 540
Dimensions & Tires:
Wheelbase: 65 inches [165 cm]
Weight: 2491 to 2690 pounds
Front tire: 5.00-15
Rear tire: 11.2-24 (2WD)
full dimensions and tires ...
Ford 1720 attachments:
snowblower
blade
front-end loader
backhoe
all 1720 attachments ...
1720 Serial Numbers:
1987: UL21001
1988: UL22701
1989: UL26556
1990: UL28601
1991: UL30784
1992: UL32230
1993: UL33920
1994: UL35013
1995: UL36435
1996: UL37607
1997: UL38466
1998: UL40069
1999: UL41414
how to read serial numbers...
Ford 1720 Power:
Engine (net): 28 hp [20.9 kW]
PTO (claimed): 23.5 hp [17.5 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD (optional)
Steering: hydrostatic power
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 7.1 gal [26.9 L]
Pump flow: 7.8 gpm [29.5 lpm]
Total flow: 10.6 gpm [40.1 lpm]
Steering flow: 2.8 gpm [10.6 lpm]
Electrical:
Ground: negative
Battery:
Number: 1
Volts: 12
Page information:
Last update: January 5, 2014
Copyright: Copyright 2014 TractorData LLC
Contact: Peter@TractorData.com
Copyright 2000-2014 - TractorData LLC. Notice: Every attempt is made to ensure the data listed is accurate. However, differences between sources, incomplete listings, errors, and data entry mistakes do occur. Consult official literature from the manufacturer before attempting any service or repair.
Thanks. He was at $5500 until the pto started making that noise. He dropped the price to $4800 and now at $4200. He says it runs great but the way I look at it is that's still 6000 hrs of wear and tear no matter how good he took care of it.
   / Ford 1720 buying help #4
I would want to make sure that all the parts that might be necessary to fix the PTO are still available.
You say you are not concerned about the PTO, so maybe you don't intend to use PTO powered implements on it, such as a rotary mower. But a tractor without a working PTO would be a no-deal for me.
What I meant was I wasn't concerned that fixing it would be an issue. I wound up passing on the tractor. Just too many hours for my liking
Does anyone know how I close out this thread. It is a dead issue
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2013 RAM 4500 (A50323)
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
24' Free Standing Livestock Panel Swing Gate (A50515)
24' Free Standing...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
