ford 1720 4wd engagement lever broke need help
   / ford 1720 4wd engagement lever broke need help #1
1720ford
lodi,wis
ford 1720
The lever pulls up and goes down like nothing is attached to it,looked under everything is attached and turns shaft going into trans.Can I pull the cover off that the shaft goes through it is held on by 4 bolts,manual does not show that partof transmission or tranfer case.
thanks in advance for any help, 1720ford
   / ford 1720 4wd engagement lever broke need help #2
I have a link below that is real good to give you anatomy of your tractor. I also attached a pdf file. I have taken the cover off on my 1700 for a look and the arrangement of the shifter fork. If you are careful you can get the cover off without damaging the gasket. if you have a bit of tear then you can put some RTV blue when you put it back together. Any pics of the where you have a problem? I think you might have a broken linkage or shifter fork or worn out sliding gear. Opening the top will lead you to proper diagnosis.
JC,
link to NH Parts website. very good source for parts break down.
https://webparts.pvassociates.net/cnh/webparts/main.php
If other links does not work than go to NH website under parts.
New Holland USA - Tractors - Agricultural machinery - Combines, etc.
  • 1720 rear transmission.pdf
First off thanks JC-jetro for the reply,
I took it apart and found that the fwd shift case had a broken stop tab.Which lets the shift pin linkage (which is also worn out) go to far, letting the detent springs and ball fly out into the transmission.So far I found the outer spring,the broken stop tab, and the ball.I am still looking for the inner spring. I ordered the new parts which they have made an upgrade for it which is an external stop plate kit,the new 4wd shift case , a new shift pin/lever, and a gasket for a total of $240.19.
My tractor is an 1988 1720 which the upgraded stop plate came on the 1989 models I think. My tractor did not have part # 38 on the attachment, part 33 had the broken stop tab and part 27 was wore on the shift pin
Thanks and I hope this will help someone else, 1720ford
View attachment 1720.pdf
   / ford 1720 4wd engagement lever broke need help #4
Cool:thumbsup::thumbsup: , It appears an easy fix once you get the parts in your hand. Pics of the repair is always appreciated.
JC.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
