ford 1715 tires
   / ford 1715 tires #1
double hunter
Ford 1715
Just bought Ford 1715,,4wd,,the tires a very worn,,it has 9.50-24 rears and 6-14 fronts,,i have access to a set of 11.2x24 rears,,,just wondering if this will mess up the 4 wh dr,,looked at tractor data and it sez the recommended tire for this tractor is 11.2x24 rears and 5.50x16 for the fronts,,any thoughts,,i wonder if I need to change the tires to 16's on the front,,Ill have to find a set of rims,,thanks in advance
   / ford 1715 tires #2
If you change the size of the rears, you'll have to go to the corresponding size for the fronts that Ford originally used .
   / ford 1715 tires #3
I'm going through similar problems, here's what I found. If it's 4wd the front tires should be 7-14 or 6-14 and the rear 11.2-24 or 9.50-24. It goes by the height of the tires not the size of the wheel. Mine now are 12.4-24 ( wrong) and they measure 45.6" as the 11.2-24 measures 43.4" the latter being the correct ratio.I found metal parts after taking the front end apart to replace a seal. If the wrong size tires/ratio from front to back rotation is off it can tear the front end out quick! The confusion is that the 1715 is a 2wd standard and that's where it calls for the 16" tire. 4wd tractor is optional and calls for a 7-14" or 6.14 front and 11.2-24 or 9.5-24 rear.
Hope this helps. Chet
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
